I have tried searches like google but the results all have to do with editing and do not give specifics
Results 1 to 14 of 14
According to MS documentation:
nSamplesPerSec
Sample rate, in samples per second (hertz). If wFormatTag is WAVE_FORMAT_PCM, then common values for nSamplesPerSec are 8.0 kHz, 11.025 kHz, 22.05 kHz, and 44.1 kHz.
nSamplesPerSec is a 'DWORD' which means it can range from 0 to 4,294,967,295.
So, *in theory*, the existing PCM WAV format can accommodate any sampling frequency up to 4.3GHz!!!! (As long as it is a whole number of Hz).
In practice, you can choose any value you like - the limitation will be whether any associated hardware supports it or not.
Whatever the sampling frequency, the maximum reproducible frequency will be exactly half that.John Miller -
so just out of curiosity, what is your application? Or is it just a curiosity?
Hence, the Nyquist theoremOriginally Posted by JohnnyMalaria
http://en.wikipedia.org/wiki/Nyquist-Shannon_sampling_theorem
http://en.wikipedia.org/wiki/Nyquist_frequency -
Trying to be practical, you'll need to stay within usual guidelines for sample rates, etc so that more mainstream applications can understand the files and be able to work with them.
That gives you sample rates of:
8, 11.025, 12, 16, 22.050, 24, 32, 44.100, 48, 88.2, 96, 176.4, and 192kHz
which when using the Nyquist theorem will give you upper frequency availabilities of:
4, 5512.5, 6, 8, 11.025, 12, 16, 22.050, 24, 44.1, 48, 88.2, and 96kHz
(these may all be a little less because of non-perfect filtering)
The last 4 items won't be available in many programs, unless they're either very recent or were made to specifically accept higher samplerate material. Also, you may be able to convert/generate and save material in that high samplerate format, but unless you have a playback system that FULLY SUPPORTS high sample rates--ALL THROUGH THE CHAIN, you won't be able to enjoy it.
Meaning, that whatever is the weakest link in your playback system (player software/hardware, drivers, soundcard/soundchips, cabling, receiver/D-to-A converter, amplifier, and speakers) will determine the highest frequencies heard. Oh, yeah--EARS, too!
Scott -
some peizos I have from a project long ago,I know they do ultrasonic,I don't have the specs on them
Peizos has strong odd harmonics, so the subject will react to 3x,5x,7x... of the test frequency. A Heil transformer is a better transducer.
@ JohnnyMalaria and Cornucopia
wonderful lessons,cool posts! 8)
@ jagabovery cool question!Do you have speakers that will output sounds over 20 KHz?
when i asked in another forum about where they do they "scientifics tests" using "what speakers with what frequence range" and i was trying to explain that for audio scientific tests they in the end was using the ears....boom,was a "blasfemia"
hy SingSingOriginally Posted by SingSing
re reading this whole cool treat i saw that your observations are very interesting and takes me to this question:
how "they" read and measure the odd harmonics,distortions,etc in piezos?
what "aparatos" and parameters are used?
thanks!
I've seen piezo tweeters go to 55KHz and should work for animal testing,piezos also don't require a crossover.The only problem is the dB level will be too high and may cause hearing damage,make sure you use a dB meter and keep the volume under 90dB.
http://www.lsu.edu/deafness/HearingRange.html -
thanks for the link about "hearing range" MOVIEGEEK,very good.
do you know another one showing how the frequences and levels are measure from piezos?...how can be measure and what tools are used? ! ?
thanks so much
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
Are Wav audio and PCM audio the same thing?
By yoda313 in forum AudioReplies: 2Last Post: 22nd Mar 2009, 15:46 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
PCM WAV file bitrate too high?
By djdust in forum AudioReplies: 1Last Post: 19th Feb 2008, 15:05 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 10:53
