I have everything ready to go but the authoring process will not complete because of this error. Could it be I am running the max bit rate too high in the encoder (HC)?
- (shrink and) mux video and audio files
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
INFO: [???] File D:\Viaje a PR - Disc 1.m2v looks like an MPEG Video stream.
INFO: [???] File D:\Viaje a PR - Disc 1 1.ac3 looks like an AC3 Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (D:\Viaje a PR - Disc 1.m2v)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 720
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : 16:9 display
INFO: [???] Picture rate : 29.970 frames/sec
INFO: [???] Bit rate : 9500000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: AC3 Audio stream 00 (D:\Viaje a PR - Disc 1 1.ac3)
INFO: [???] AC3 frame size = 1024
INFO: [???] AC3 AUDIO STREAM:
INFO: [???] Bit rate : 32768 bytes/sec (256 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 9963496
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio bd: buf= 16384 frame=000000 sector=00000000
++ WARN: [???] Stream e0: data will arrive too late sent(SCR)=312385097 required(DTS)=0
++ WARN: [???] Video e0: buf= 172634 frame=104020 sector=01772717
++ WARN: [???] Audio bd: buf= 13987 frame=108464 sector=00055093
INFO: [???] Scanned to end AU 125170
INFO: [???] STREAM bd completed @ frame 130516.
INFO: [???] STREAM e0 completed @ frame 125170.
INFO: [???] Multiplex completion at SCR=375880557.
INFO: [???] Video e0: buf= 3743 frame=125170 sector=02127410
INFO: [???] Audio bd: buf= 8192 frame=130516 sector=00066295
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 5841886 bytes
INFO: [???] Sequence headers: 6984
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 125170
INFO: [???] No. Groups : 6984
INFO: [???] No. I Frames : 6984 avg. size 67867 bytes
INFO: [???] No. P Frames : 34821 avg. size 54394 bytes
INFO: [???] No. B Frames : 83366 avg. size 23183 bytes
INFO: [???] Average bit-rate : 8237600 bits/sec
INFO: [???] Peak bit-rate : 9499600 bits/sec
INFO: [???] BUFFERING min 15 Buf max 235543
INFO: [???] AUDIO_STATISTICS: bd
INFO: [???] Audio stream length 133649408 bytes.
INFO: [???] Frames : 3659283367
INFO: [???] BUFFERING min 35 Buf max 14368
**ERROR: [???] MUX STATUS: Frame data under-runs detected!
Results 1 to 10 of 10
You are within the bitrate limits (just!) but I think the warning you recieve is the issue. DTS & PTS must be after the SCR for a given packet. mplex claims you have DTS=0 when SCR=312385097 ...
OK, thanks but what does that mean in English or Spanish?
I'm afraid I am a bit of a newbie with DVDAuthor or mplex (on which there is scarcely any information on the web).
I suspect the issue could be with the m2v and ac3 files I am trying to multiplex since tried Muxman and got a similar error along this lines:
"The buffer underflowed 6 times. Resulting DVD may not play smoothly"
The .m2v file was encoded with HC and the .ac3 file with Aften (a project based on AC3Enc but with improvements).
Any suggestions? -
All dvd's i seen that play ac3 with two channels are encoded at 192kbits. Maybe if you can re-encode to a lower bitrate it would help? Mplex should output detailed parameter listings with mplex --help I use dvd styler which includes the dvd author package and its parameters when mplex is called upon are mplex -f 8 -S 0 -M -V -o "outputfilename.vob" "inputvideofile.m2v" "inputaudiofile.ac3/wav/mp2" I would also try to encode that video at a lower bitrate since its pushing the envelope a bit. I like to allow for an margin error of 10%, that is go 10% less of what the theoretical maximum is allowed and if you can use variable bitrate then the quality loss should be less if you are already using CBR.
Thanks,
Rauli -
Well, I tried a 192kb stream just for kicks but the problem is still there. In fact, I tried to reproduce the problem using a 10sec clip from the video that is generating the errors but encoded at bitrates higher than spec and the muxing goes by smoothly.
Perhaps, the much longer original video gives more chance for errors operating at high bit rates?
It takes 14 hours to encode the whole video on my feeble computer. This is why I am trying to find an explanation before switching to trial and error on the whole video.
These are the command line options used by GFD on mplex:
-f 8 -o "d:\output.mpg" "D:\input.m2v" "D:\input.ac3" -
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I use HC a lot. If it's done a pulldown on 23.976 -> 29.97 fps occasionally muxers complain the GOPS are too long. But they always play perfectly.
I've had hassles with AC3, but MP2 always works. If you don't really have or need surround sound, convert it to MP2 stereo. BeSweet can do this pretty easily. -
I tend to think it there is an issue with my source m2v or ac3 file since I am getting problems with two different multiplexing programs.
I will try an mp2 file tonight instead of ac3 and see what happens although my guess is the same problem will happen.
If all else fails I will have to re-encode the whole thing again at a lower peak bit-rate to try and make the problem go away. -
i fixed it while adding nav packets in debian linux. my reply is in a different post here
https://forum.videohelp.com/threads/282317-data-will-arrive-too-late-what-am-I-doing-wr...=1#post2360866
i don't know if this will fix your problem, but i want to write it here for something to try because it will probably work because i got the same exact buffer underrrun error
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:00 -
GUI for DVDauthor - error opening MMbackg.mv2 file
By PCH in forum Authoring (DVD)Replies: 27Last Post: 24th Jul 2008, 03:20 -
GUI for dvdauthor: The infamous SCR error.
By jedinix in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2008, 21:51 -
GUI for dvdauthor AC3 error
By rancid in forum Authoring (DVD)Replies: 6Last Post: 3rd Jan 2008, 23:25 -
Need help w/ GUI For dvdauthor - Demuxed mpg throwing Discontinuity error.
By palouse in forum Authoring (DVD)Replies: 4Last Post: 15th Oct 2007, 18:33
