Hey guys, all of a sudden when play a movie, video clip etc on my system i have notived that the colour is not right, it is quite dark, now this is happening with real player, windows media and PowerDVD, anybody have any idea what could have caused this and how i can fix it?
Many Thanks!
Forgot to mention that it is happening with all types of videos including playing straight from a DVD
Here are some specs
OS:Windows XP
Processor:AMD Athlon Dual Core 64
Graphics Card: NVIDIA Ge-Force 6600
The only codec pack i know i have installed is DivX and XVid, I have recently updated drivers for the card which was last week
And it is only the Vids that are dim and nothin else -
All those programs use hardware overlay. Check your graphics driver's overlay settings.
Right i know i said bout that i solved the problem but i really havent im having trouble trying to get the setting right
Here is an image of the settings panel
http://i35.photobucket.com/albums/d152/Squid_uk/Nvidia.jpg
Could anybody tell me what the standard setting would be? -
That dialog says "Overay is disabled". You need to enable overlay for those controls to work.
Nvidia always seems to screw up the overlay settings when you update drivers. The thing to do is disable overlay, close the dialog, reenable overlay, then adjst the settings.
Computer monitors are very different than TVs. Video that looks fine on a TV will look dark and over saturated on a computer monitor. -
It was disabled i was actually playing a video clip when i took the screen shot
TBC colour cast problem. Or is it a problem?
By SilverUnicorn in forum RestorationReplies: 0Last Post: 29th Jun 2011, 18:21 -
Monitors and colour.
By dfgh11 in forum EditingReplies: 3Last Post: 6th Jan 2011, 11:44 -
Help with colour banding...
By FNi in forum EditingReplies: 6Last Post: 2nd Oct 2010, 21:15 -
Menu Colour
By sambat in forum Authoring (DVD)Replies: 0Last Post: 26th Apr 2010, 08:54 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 19:10
