Pinnacle Studio 9 plus has a very useful feature called Smart Capture: You can capture DV video in very low quality format , edit it and when its time to produce your movie the program recaptures the necessary footage automatically from the original DV tapes (based on time code) in full resolution . This way you can have 50 or more hours of video in your hard disk . The Pinnacle guys remove this unique feature from version 10 !!! And now i must purchase a hard disk of 1000GB to do my job!
Does anyone knows if there is another video editing application that has a similar feature?
If you need to wade through hours of capture to pick the few minutes of interest, then this is still a good feature. For most it is no longer needed as drive sizes increase. I agree that you should keep v9 for this purpose. Nobody else at the consumer level is doing this.
yes i want to have hours of video cause i make compilations of the video footage i have shot and scanning all the time the mini dv tapes is not comfortable. So as i understand the only solution is Pinnacle Studio 9 . I wanted to try something else because the version i have (9.4 plus) is very buggy and its crashing all the time, forcing me to save almost every 4-5 actions i take... Thanks anyway for your help
Have you looked to see if Liquid Edition does this (it is less buggy), and you can pick it up on ebay for a decent price if you are patient.
Rob
Copying "Rango" and similar DVDs
By dphirschler in forum DVD RippingReplies: 14Last Post: 22nd Nov 2011, 03:03 -
Was it the iphone that replaced the word "program" with "application"?
By yoda313 in forum Off topicReplies: 6Last Post: 16th Mar 2011, 08:52 -
Looking for a video editing feature similar to "Shadows/Highlights" from PS
By vitwa in forum EditingReplies: 5Last Post: 6th Mar 2010, 17:21 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 13:59 -
TMPGEnc DVD Author 3 DivX "Smart Rendering" Bug?
By ln108 in forum Authoring (DVD)Replies: 7Last Post: 23rd Aug 2007, 11:27
