I have a series of avi movies , and want to play them from the dvd disc on my pc.9 no remote)
i know i can drag an avi file from explorer to the player, i was wondering if there is a simple way to choose the movie in the player (classic media player or bs player) the dvd menus in the guide seem to complicated for this task.Thanks ,Lin
No such thing is possible as there's no standard for a menu system.
Thanks , il'l look no further then ,just drag n drop .Originally Posted by kschang
Lin -
Using the new DivX format (an "extension" of AVI), you can add a menu. IIRC, there's something like DivXMediaBuilder to use. However, the standalone player support is slim, to say the least. Look for DivX Ultra certified players. Software players are also limited, but DivX own player should work.
/Mats -
You can create a simple html web page with relative links to your videos. The menu would only work when viewing the DVD on a PC, but that was your plan anyway.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Under Windows you can just use Explorer to navigate to the DVD and display the file list. Using a media player you can use the File -> Open dialog.
Set-top Divx/DVD players will show a simple text menu of the AVI files on the DVD. Use the remote to select the one you want. There is sometimes an option in the player's setup for menu or autoplay. -
Thanks for your replies,il'l look into creating a html web page
Originally Posted by drjtech
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 14:47 -
I need to make a simple slideshow DVD
By jeffzilla in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 03:52 -
DVD software to make simple divx data disk
By gthorley in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 14:28
