Hi,
I am trying to save audio from avi file as wav in full processing mode with VirtualDubMod.
As I click "Save wav", I get error mesage: "No audio decompressor could be found to decompress the source audio format"
This probably means the proper audio codec is not installed but once I open the avi file in AVICodec, it shows: "Audio: 47 MB, 58 Kbps, 32000 Hz, 1 channels, 0x55=Mpeg-1 audio Layer 3 (MP3), Supported" which means all required codecs are installed.
What is the problem here? Thank you.
Results 1 to 9 of 9
Either your mp3 ACM decoder is broken or there was a problem with VDub where certain headers would cause the above error. Wouldn't have thought it would have effected the latest version. On the offical forum there should be some posts on it, including how to fix the header via HEX editing. Otherwise just use something else to decode.
Hi,
Thank you, guys. The problem is that all the stuff is very much unfamiliar to me. But it looks like I have found the way out.
I've been using ImTOO MPEG Encoder for a while and must say it is a good thing.
I tried to demux and convert the audio from the AVI with its help and I believe it worked. I set up WAV as a target and I get "moviename.wav" file with the size of 1.11 GB.
Based on the volume it must be uncompressed WAV.
What would be your opinion? Thank you.
P.S. The file information provided by the same program:
- Format: pcm_s16le
- Bit rate: 1411kbps
- Sample rate: 44100Hz
- Channels: Stereo
Full Backup Mode in BD Rebuilder
By fjmr in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jul 2009, 03:32 -
Full screem mode
By sat-jokar in forum Video ConversionReplies: 3Last Post: 29th May 2009, 08:36 -
VirtualDubMod and Save WAV problem...
By bla4free in forum AudioReplies: 7Last Post: 9th Oct 2008, 15:53 -
Full Processing Mode vs Fast recompress?
By rocky12 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 07:07 -
Problem "Full processing mode" in VirtualDub
By jonaskarlsson in forum AudioReplies: 11Last Post: 11th Aug 2007, 21:30
