I have a digital camera Kodak V530. Besides taking still photos, it can also capture video at 640x480 OR 320x240 resolution, in MPEG-4 format.
I have been capturing using 640x480 and use the software tool ConvertxDVD (something like that) to convert the MPEG-4 video clip to DVD. This is pretty quick and easy to do.
I am wondering if there are tools to convert the MPEG-4 clips to VCD, I mean one step process and quick just like the one for converting to DVD mentioned above.
You maybe wondering why I downgrade to VCD format. There are several reasons:
1) 640x480 video (30 fps) is a little bit jerky due to the speed of my SD memory card
while the 320x240 video always look smooth
2) the clips I captured are just for fun and really not meant to be converted to a fancy DVD with transitions & titles as I used to do with with a DV camcorder.
3) I have a portable 7" DVD player that can play all kinds of video / audio formats. A VCD and DVD shows about same video quality on this one.
ktnwin - PATIENCE
NeroVision....but I would use Tmpgenc Plus and VCDEasy.
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 10:17 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
