Hi,
I've got synchronization problem while muxing m2v and ac3 after encoding avi to DVD NTSC with Procoder. The problem is there no matter whether I encode from PAL or NTSC and it is progressive desynch. I am not sure whether I demux the audio in the right way with VirtualDubMod and save it.
I use "Demux" option in VirtualDubMod and save the resulting AC3 file. After that I disable the audio stream in the AVI and save it without audio.
Is it the right way to do it or I should save the audio as a WAV file? Can this affect the synchronization?
I checked the runtime of the AVI without audio and the AC3 file. Both have the same runtime.
Thank you!
Hi,
If I've been experiencing sync problem with every conversion from AVI to NTSC DVD for the last time.
If video conversion is done right and audio also muxed right, could it be that some codecs or some other software create the problem?
Audio Demuxing
By jcj0487 in forum AudioReplies: 2Last Post: 5th Apr 2011, 03:07 -
Demuxing Problem
By jpmccusa in forum Authoring (DVD)Replies: 8Last Post: 18th Mar 2010, 19:10 -
Demuxing DL problem
By calanda in forum Authoring (DVD)Replies: 9Last Post: 15th Feb 2010, 23:52 -
[SOLVED] WMV to MPEG4/AVI/anything else has increasing audio desynch.
By Eilonwy05 in forum Video ConversionReplies: 13Last Post: 15th Jun 2008, 14:01 -
Problem with Demuxing
By Elvish Hero in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 03:56
