Let me say first that I am a newbie to all this and this is my first post.
I'm trying to capture to record to S-VCD on my ATI AIW Radeon 128 32 mb. I'm not sure if I have the setings correct
because the only info I got from the walkthru on this site is for VCD 2.0
Here's what I have going...
Video standard lines = 525
Size = 480 x 480 MPEG-2 (deinterlasing & visual masking checked)
Frame sequence at default (4 & 2)
VBR @ 2.6 Mbs
Motion Estimation Quality @ 99
Search Ranges @ 32 & 16
Is that what I need to capture for a S-VCD?
Second...I'm getting an error when I hit the capture button. It tells me..."Atimmc has
caused an error in ATIDVCR.DLL Atimmc will now close"
I've un-installed and re-installed all my software twice and still get the error.
Anyone else have this problem?
Here is my system...
AMD Athalon 1.4 GHZ
Asus A7V266 motherboard - Via chipset
512 mb PC2100 DDR Ram
60 Gb 7200 rpm ata 100 hard drive
...software...
WinME
DirectX 8
Directx 8 DV/video cap update
ATI drivers 4.13.7189
ATI MMC 7.1
ATI DVD 4.1
...other software installed...
Huffy 2.1.1 codec
PicVideo 2.0
Virtual Dub 1.4.8
CapTV 1.4
Thanks in advance!
