    Jan 2003
    Nassau, Bahamas
    hi guys.....todays my anniversary, and i just wanted to know if there is any software out there i can use with my webcam, to record sound and stuff, so i can send a vidmail to my wife. im willing to pay for it, i just dont know trhe name of any....can u guys help me out...holla back
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Hi,
    Virtualdub should work with your webcam, but because it is a USB device the recording will look like slow motion, you need a microphone to record the sound, and configure the sound properties to record from mic.
    For the smallest possible file size you might download and install the DivX codec and compress the final edited file with it, you will find guides to do this in the forum guides.
    No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
    Jan 2003
    Nassau, Bahamas
    any other programs would you recomend, also....how do i configure vdub to capture
  4. What webcam do you have?
    John Miller
  5. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    Go here and take a look:
    https://www.videohelp.com/tools?s=5#5
    I am not sure if most would work with USB webcams though.
  6. Member Abbadon's Avatar
    Dec 2003
    Caribbean Sea
    http://virtualdubbook.packtpub.com/preview_chapter3.htm
