Hi,
Using Quicktime 7.1.3, ffmpegX v0.0.9w r5, OS X 10.4.8.
When I convert an avi to DVD using DVD ffmpeg, it works just fine, but does not preserve the letterbox format of the original file.
When I choose "Decode with QT (letterbox)" on the Options tab, it preserves the letterbox format, but the video pauses every second or so.
I've searched the forum, and tried several options, but nothing works.
Can any one suggest something that will work?
TIA,
Charles
Try DivX Doctor on the AVI. Check the settings that would produce a separate QT movie. Drop that movie onto ffmpegX.
Let us know what happens.
What Quicktime components are installed?
I'm asking because the 3ivx 4.5.1 decoder under QT7 has a tendency to give jerky playback. (If you've got it installed, there's a 4.5.2 version that is distributed with 3ivx Crush that fixed it for me. Do a "show package contents" and look around and you should find it.)
Another possibility is to run it through MPEG Streamclip and export as QuickTime (MJPEG-B) as best quality. Then drop the resulting file (it will be large) onto ffmpegX.
Jacke - When I opened DivX Doctor II it told me I don't have 3ivx MPEG-4 installed, and that I should get a copy. I downloaded the demo of 3ivx Crush, installed it, and DivX Doctor *still* tells me I don't have 3ivx MPEG-4 installed.
Waz-up-wid-dat?
rumplestiltskin - The movie that was created when I dropped my .avi onto DivX Doctor II has all white video. I used the default settings, which indicated that I should get a stand-alone movie and it should auto-run.
Ahem...Waz-up-wid-dat?
From the .nfo file:
AUDiO......[ MP3 48000Hz 112 kb/s CBR (2 chnls)
ViDEO......[ 794 kbps XviD 23.976 FPS
Q.FRAME....[ 0.236 bits*pixel)
RESOLUTiON.[ 516 x 272 (1.897 (55:29))
XViD DATE..[ 09/28/2006
SUBS.......[ None
FiLES......[ 1
SiZE.......[ 701 MB
SOURCE.....[ NTSC DVD
I have had success!!!
Haven't burned the DVD yet, but I used Toast to save the .avi as a DVD-DL image, and that worked. I will burn to single-layer DVD with compression.
I used "Best Quality" and Half-PEL.
Thanks for the help, can you recommend other settings for custom encoding in Toast or point me to a tutorial?
Jerky Video.
By wasimismail in forum Video ConversionReplies: 27Last Post: 15th Dec 2009, 11:35 -
Jerky video playback
By realmfighter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Nov 2009, 01:41 -
jerky video with quicktime 7.1
By clk1946 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 23:54 -
video still jerky
By milway in forum Video ConversionReplies: 15Last Post: 3rd May 2008, 16:01 -
Video is jerky
By arnie22112000 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 00:49
