Results 1 to 9 of 9
  1. I just ran what seems a handy utility called Sherlock (to complement GSpot and AVIcodec), which I obtained here
    http://www.updatexp.com/sherlock-codec-detective.html
    It reported one codec was broken::
    "DivX MPEG-4 DVD Video Decompressor
    The driver file for this codec was not found.
    This probably means the codec was not uninststalled properly."
    How do I proceed please? The codec wasn't in Add/Remove, and I'm darned if I know what program it 'belongs' to...
    Terry, West Sussex, UK
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    you might try codec sniper to see if it can clean it up.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
    Aug 2003
    Denmark
    In Windows go to "Start / Control Panel / Sounds and Multimedia" and chose fan: "Hardware"
    Move down and open: "Video codecs"
    Then chose fan "Properties" and select the codec and hit the remove button.
    Regards
    Pol
    Dec 2004
    Australia
    Looks like a directshow filter, not a VfW codec.
  5. Originally Posted by politiken
    Regards
    Pol
    Thanks, appreciate the fast reply. But as you see, that list doesn't seem to include the one in question:
    Cinepak Codec by Radius Inc.
    DivX 6.4.0 Codec
    Fraps Video Decompressor
    Huffyuv lossless codec [HFYU]
    i420vfw.dll
    Indeo codec by Intel
    ir41_32.ax
    iyuv_32.dll
    Lagarith lossless codec [LAGS]
    Ligos Indeo Video 5.11
    Microsoft RLE Codec
    Microsoft Video 1
    Microsoft Windows Media Video 9 VCM
    MS MPEG-4 v1,2,3 driver 4.1.0.3927
    msh261.drv
    msh263.drv
    msyuv.dll
    pdvcodec.dll
    tsbyuv.dll
    vvlcodec.dll
    XviD MPEG-4 Video Codec
  6. Originally Posted by Forum Troll
    Thanks. But I got error message (in German?) on running it.
  7. Originally Posted by celtic_druid
    Yes, thanks, does that square with what I've now found? I used a program called DS Filter Manager, which showed it as having a 'merit' of 'Preferred'. For the time being I've changed that to 'Do not use'. Can't say I really know what I'm doing though! In particular, would still like to know what program installed this codec.
    Dec 2004
    Australia
    Would have come with DivX. Either that or it came with something else that licensed or "borrowed" the decoder.
    Any of these apps give a path/name of the missing filter?
    Re installing DivX should re-register it.
  9. Originally Posted by celtic_druid
    Excellent, thanks - that seems to have fixed it. After I re-installed DivX, Sherlock ran without reporting any 'broken'. Then I ran DS Filter Manager and changed the 'merit' of this DivX MPEG-4 thing (listed in the DirectShow section) back to Preferred. Closed that and re-ran Sherlock. Still no 'broken'. Hopefully there won't be any side effects. And who knows, it might even have fixed some of the quirks I've been getting in MemoriesOnTV!
    Much appreciate your help.
