Is is version of VLC allowed to Screen Capture?
if it 's posssible
how?
thanks in advance
To be more specific.
Right-click on the video window and select 'Snapshot,' or select the same option under the Video menu. (Note: neither Snapshot option will appear unless you have a video loaded.)
This should save a snapshot to whatever directory you have specified under Preferences > Video > Snapshot > Video Snapshot Directory (however, I don't know where it'll go if you leave the field blank), in either PNG or JPEG format (depending on which format you have selected in the Video Snap Shot Format option underneath the Video Snapshot Directory field.)
If cameras add ten pounds, why would people want to eat them? -
i didnt see the snap option..
so i asked
is this version allowed to snap?
i am not sureTo be more specific. -
i dont want a bigger fatter program
so i hesitated to update to the lastest versionTo be more specific.
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
VLC Media Player - "Lost Frames"
By Ancalagon in forum Software PlayingReplies: 3Last Post: 18th Feb 2010, 05:57 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 05:08 -
AVI file "broken" when played with VLC
By Salva Veritate in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2007, 12:01
