Hiya guys I use CCE to convert movies and I've just installed the software on my new pc. The version I'm using is Cinema Craft Encoder SP Version 2.70.02.10.
I'm using windows xp service pack 2 I beleive, and although the process continues I get a weird kind of error message pop up once the mpv file had been converted. This is it.
My movie was then out of sync. Any ideas what can correct this problem guys???
I believe that similar errors have been posted before, and in most cases related to the dubious way the software was acquired. If this is not the case here, and you did pay your $2000, I suggest you avail yourself of official support channels.
Read my blog here.
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 11:09 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Annoying error i keep getting...
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 04:33 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
