Results 1 to 9 of 9
    Dec 2005
    Canada
    I just burned a movie on a DVD but when I play it in my DVD player, it's all scrambled and it's flickering all over the screen... I can't see a thing !!!!!
    this never happened to me before, so I tried burning another one.. still the same problem occured
    can anyone tell me what's wrong???
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Is it a PAL DVD? If so maybe your DVD player is having an issue with sending the Video to your TV. What DVD player is it?
    Use Media Player Classic, Open it up and Click on View, then Information. If the DVD is 720 x 576 then it is PAL, if it is 720 x 480 then it is NTSC. Good Luck
    Dec 2005
    Canada
    it's a panasonic dvd-s52...
    and I believe it's an NTSC movie.. is there any way to look it up when I put the dvd in my computer? because the movie works in my computer's DVD-rom
    Dec 2005
    Canada
    oh well.. its 720*576.. guess it's PAL :]
    is there anything I can do to fix it?
  5. Aging Slowly Bodyslide's Avatar
    Feb 2002
    See if there is a hack to make your player play PAL dvd's or convert from PAL to NTSC
    Dec 2005
    Canada
    would it be possible for me to take the .iso / img file I have and convert the movie to NTSC ?? can I do it with dvd-shrink?
    I just checked, they are no hacks available for my dvd except a region hack!
  7. Aging Slowly Bodyslide's Avatar
    Feb 2002
    Check the settings on the player and see if you can change the Video setting from NTSC to Auto. I can choose Auto,NTSC or PAL on my players...
    You can extract the files inside the ISO and convert them from PAL to NTSC. Do a search for PAL to NTSC to see how...
    Here is a Panasonic Forum that might help some.
    http://www.dcevolution.net/panasonic/
    Dec 2005
    Canada
    alright thx for your help!
  9. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Either look for an All Region player on Ebay (for instance) or use FulciLives conversion process (which worked for me on my first try with R2 Razorback) here:
    https://forum.videohelp.com/viewtopic.php?t=300144
    The Fulcilives process is more fun, though very time consuming, but the Multi-Region player is easier, just don't know how reliable.
