Hey
I'v been using muxman for awhile now and yet not stumpled over this problem
In muxman you can only add 8 subtitles, I never had to add more but is there a way to add more? or is there another tool as good as muxman that will allow me to add more subtitles?
Hi-
8 is the max unless you buy the Pro version.
If you want more, mux using IFOEdit (up at the top, DVD Author->Author new DVD). It takes all the stuff the same as does Muxman. ReJig also authors the same way. I don't know how many sub tracks it takes as I've never used it.
As for being as good as Muxman, nothing is quite as good, but I've never had any problems with IFOEdit authored DVDs. -
You can also use MuxMan for this purpose. But you need to declare the additional subtitles streams in the mxp file yourself (using a text editor). MuxMan supports up to 32 subtitles streams, only the (freeware version) GUI is limited.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
