I have a .avi that I want burned onto a DVD. The file is perfect. Nothing wrong, no audio or video problems. All the way through. I opened Toast Titanium 7.1 and went to burn it. Everything went fine. Finished product, horrible audio sync problems.
So I decided to use iDVD instead. Made my project, and instead of wasting another DVD, I just made a disc image, mounted the image and the same thing happened, horrible sync issues, but different spots, not the same problems.
What can I do? Should I re-encode it with ffmpegX and use that? And hope it works? Extract the audio and re add it?
Is there a avi fixer for Mac that anyone knows about?
The .avi file is fine, but something in it is screwing up my audio once burned.
Any help would be greatly appreciated.
thanks,
veganjustice
D-Vision is great for fixing avi files, i would then suggest getting mpeg2works to convert them for a dvd...
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 10:36 -
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 13:09 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 07:40 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 12:52 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 00:38
