Hi
So i bought some DVD-R DL (VERBALTIM) trying to burn a DVD-9 ISO. But when using imgburn, i get an error that says DVD-R DL cant set layer breaks. So if i burn it would it be skips in the movie? What should I do to make a perfetct copy? I got the mds files though.
Help appriciated.
kofstuff,
It's not really an error to be unable to set a layer break if you're using -RDL media, it's just the way it is. Almost everyone uses the +RDL because of all the problems using -RDL. You may want to save the -RDLs for data, and get some +RDL Verbatims for your dvd-video. You'll have a lot less problems burning, and getting your player to actually play the disk.
I see this was your first post here, so welcome to VideoHelp.
Trouble Burning on DVD Architect
By croonprince in forum Authoring (DVD)Replies: 0Last Post: 6th Dec 2011, 17:46 -
Having trouble burning a DVD off of my DVR
By RRFeeney in forum Newbie / General discussionsReplies: 2Last Post: 1st Oct 2009, 15:57 -
trouble burning MPEG to DVD
By desert_dick in forum Authoring (DVD)Replies: 1Last Post: 19th Aug 2009, 15:22 -
Trouble burning DVD+R DL with Pioneer burner
By RoyGBiv-inRI in forum DVD RippingReplies: 11Last Post: 17th Oct 2007, 11:43 -
Trouble burning/detecting DVD+R DL
By lowdirt in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 03:23
