Hi,
I got a great recommendation here to try WinDV for capturing my video off my Canon MiniDV camera. The quality of the video is definitely better than what I was getting with Windows Movie Maker.
But there's one problem. The WinDV program breaks up the output into files that are 2.7G each. I can't figure out how to "sew" them back together, so I end up having all these snippets that start and end at random places.
I'm using NTSF, not FAT32, and I definitely have other files on system that are larger than that.
Can anyone tell me how to fix it so I can just get one big file as the output of WinDV?
gary in vermont
Originally Posted by garybeckJohn Miller
DV format is encoded in the camcorder and recorded to tape as a data stream. There is no "file" in the OS sense. To "transfer" the data, you play the data stream back at 1x through the firewire (IEEE-1394) port where it gets captured to a file at the computer. There is no "codec" envolved because it is just a data transfer.
Data streaming is different than "file copy" which is managed by the OS. If the disk is busy, there is no resend so data flow is interrupted and lines or frames are lost.
In order to display the picture during the transfer, the DirectShow MS-DV codec is used to decode the stream to show the video and audio being transferred. This is a separate process from the DV data transfer itself which is not decoded. Decode for monitoring purposes does impact CPU loading and the software author can select quality levels for display. High quality display may overload a weak CPU so it is seldom used.
Broadcast level DV equipment extend this concept two ways. First higher cost (I mean much higher cost $$$) mechanical transports can run the stream faster to shorten transfer time. This is important if you are paying hundreds of $ per minute for satellite time or paying a tape operator to load the server.
The second "high end" strategy is to include a CPU and operating system on the camcorder. Then the camcorder becomes a node on the network and "files" can be created on the remote media (e.g. tape, DVD, hard disk, flash media, etc) and then files can be transferred over networks in standard ways. This technology will soon enter consumer and prosumer equipment.
PS: If your computer is overloaded by the DV monitoring task, a similar program called DVIO will do the transfer without monitoring, thus reducing CPU load. In this case you would watch the camcorder monitor to see what is being sent, then review the resulting file to see if it was all received.
can someone explain why extracted files are larger?
By mickthetree in forum Newbie / General discussionsReplies: 7Last Post: 8th Dec 2008, 22:28 -
Is it possible to encode divx files to larger than 5gb?
By yoda313 in forum Video ConversionReplies: 18Last Post: 4th Jul 2008, 11:25 -
WinDV splits files
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 24th Jun 2008, 01:03 -
Rendering should yeild smaller, not larger files right?
By InFlames814 in forum EditingReplies: 9Last Post: 4th Dec 2007, 22:21 -
WinDV - why so many AVI files from one single tape?
By geek2330 in forum Newbie / General discussionsReplies: 11Last Post: 20th Jun 2007, 20:53
