Hi. I'm trying to make an animated gif using captures from a divx file. Can anyone point me in the right direction on what software i could use and a good method to do it?
Open your clip using VirtualDub http://www.virtualdub.org
Using the slider at the bottom, or by using Video -> Select range, select the range of frames you want in your GIF animation.
Click File -> save Image sequence. You can save the series of frames as BMP images.
You will need to use a Animation tool - search the internet for shareware GIF creation tools. You can load the created images into the GIF creation software and create your animated GIF. -
Load the AVI into Animation Shop 3, it comes with Paint Shop Pro 7. Select rage or load all frames !!!
http://www.jasc.com/ download a free demo (Fully working)
Hauppauge capturing frames problem
By richiexd in forum Capturing and VCRReplies: 4Last Post: 18th Jan 2012, 22:18 -
capturing avi frames
By Willy5157 in forum Video ConversionReplies: 2Last Post: 8th Jul 2008, 19:22 -
Getting artifacts and dropped frames capturing DV
By CleanRich in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Nov 2007, 20:54 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59 -
Capturing problem.. Dropping frames..
By azazel_dx in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th May 2007, 15:47
