I have an old pc running windows 98. I was able to backup several movies before DVD Fab upgraded. I tried to upgraded to the new DVD Fab Decrypter 3 and now it will not open. I have tried all three releases with the same results. It says it install fine but when I double click on the icon it opens then I get an error box. Saying that DVD Fab Has an error and needs to shut down. What could be causing this? Like I said it was working fine before I upgraded.
Thanks,
Robert
Results 1 to 11 of 11
Have you tried to contact Fab directly about the problem? I remember reading a topic a few days ago that someone contacted them about a problem, and they quickly responded and fixed the problem. Few people are using W98, and they may not know about the problem.
Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic -
Yes I contacted them when they first released 3.0.2.0 about the problem. And I have yet to hear from them.
I have the same problem and I am using windows xp home edition.
Version 2 never had this problem. -
I am running Windows XP Pro SP1 & i have updated DVDFab Decrypter as they have come out and i have had 0 problems with it......
Windows 98
Way past time for an update. -
I agree,you can get the XP OEM CD for ~$80USD and it will be supported for several more years.Originally Posted by Noahtuck
Have you tried DVDDecrypter? -
If win98 accomplishes what you need to do on a computer, there isn't much motivation to change. According to this fairly recent analysis (based on computers connected to the internet), more people are using win98 than the combined Macintosh os's, more than WinMe, WinNT, Linux, etc. In fact, it's the third most popular os (xp at 87% is the leader).
Besides being win98 compatible, the "PSL2 Plugin for PgcEdit" uses DvdDecrypter and FixVTS much like RipIt4Me does, and works on the newer copy protections that DvdDecrypter can't handle on its' own. -
There's also a difference between 98 & 98SE,98SE and Me are closely related and have better support.
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 18:02 -
dvd fab HD Decrypter 6.2.0.5 help
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2010, 04:55 -
DVD Fab HD Decrypter your drive matters
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 18th Jan 2009, 11:09 -
DVD Fab HD Decrypter?
By wulf109 in forum Blu-ray RippingReplies: 20Last Post: 16th Sep 2008, 14:41 -
New to Board DVD Fab HD Decrypter 4 Question
By marine89052 in forum Authoring (DVD)Replies: 3Last Post: 28th Mar 2008, 00:33
