Hi all,
Got a cheap DVD player - Umax/yamaha chili DVD-2400X - and trying to find a firmware upgrade for it. Converted some TV recordings with a newer Xvid source code and now parts of the programme have a random blocky effect. Anyone know of a available firmware upgrade for the above player, or somewhere i can go and search for one?
jimbop14
If there is one, it would be on the manufacturers website, many don't offer them.
Your best bet, would be to encode all your files into a format your player supports.Google is your Friend -
Umax have a website, but don't list my model. I was wondering if i could flash the firmware of another, well supported DVD-player, abit like the sony/lite-on dvd-writers? And no website like the dangerous brothers for DVD-writers, only for standalone DVD-players instead?
I only persist, as i have deleated original mpeg2 files so will have to re-encode Xvid to older Xvid - something i want to avoid if possible for obvious reasons.
Thanks for any more help
Cheers
Jimbop14 -
It will have to be firmware for your specific hardware. You can't just choose any at random.
Divx version usually isn't an issue, it is usually a matter of your files not meeting the specs you player requires.
Go to the DVD Players section, download and burn the test cd. You can then use it to see what file types your player supports.Google is your Friend
Lg dvd player firmware help urgent
By righteous818 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th May 2011, 19:39 -
Firmware for Toshiba HD DVD player
By tmelo38 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 1st Nov 2007, 19:02 -
How to do firmware upgrade for a DVD Player
By Tiger_Lion in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2007, 00:33 -
DVD Player Firmware
By abercrombiedude0409 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 13:10 -
Tevion DVD Player Firmware?
By romi7519 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jul 2007, 06:36
