I've a H264 file that I wanted to convert to Mpeg2.
I had an issue with that, but resolved it by installing ffdshow.
Tmpgenc will now convert the file, but I find the video is either stretched on the vertical (Every one is very thin) or I get the sides cropped.
This is after playing with the various options, but TBH I've no idea what I'm doing.
I have tried a couple of things in the tutorials, but haven't found out how to keep the correct aspect ratio along with all the frame.
I'm using tmpgenc plus 2.5
The video is in H264 format (1280*512 - 2.50:1) with AC3 audio.
Quite new to all this, so thanks in advance for any help..
Paul.
"Keep aspect ratio" under settings->advanced->video arrange method, has alwayed worked fine here.
I know I've tried several options from that drop down box, will have to try again with that one to make sure..
Cheer though. -
If the sides are cropped when watching the DVD on TV but not when watching on the computer the issue is overscan. All TVs draw a picture that's larger than the visible area of the screen. That's so you don't see junk at the edges of the frame and to hide framing and linearity problems. You end up losing about 5 percent on all four edges.Originally Posted by MrRalphMan
If you want to see the entire picture you have to add black borders around the picture so that the border is hidden by overscan, not the edge of the picture. You can se FitCD to show the resizing and padding parameters. -
Your video is not 16:9 (likely 2.35:1) and you have to add horisontal black bars to complement it to 16:9 before resizing to 720x576 and encoding with 16:9 PAL DVD template.
Thanks, that sorted it and thanks for the other replies..Originally Posted by Baldrick
Cropped Video, Now Need to Encode
By Punkin444 in forum EditingReplies: 9Last Post: 7th Dec 2011, 11:09 -
Blowing 4:3 cropped video to 16:9
By carlmart in forum Video ConversionReplies: 4Last Post: 1st Jun 2011, 09:40 -
The video is cropped on my TV, subtitles are trimmed/cutted/cuts off
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 15th Dec 2008, 22:22 -
Cropped Edges on Playback
By madrabbit in forum Authoring (DVD)Replies: 11Last Post: 12th Mar 2008, 17:31 -
All my AVI's seem to come out cropped
By saihossoku in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 00:43
