i have loads of TV episodes i have been given by a friend who put them onto my hard drive. i want to copy them onto a playable dvd but by using nero7 i can only fit maximum of 2 files on a dvd. Is there a program i can use to fit more clips on. THe clips are about 45 minutes long at resolution 640x352 and audio bit rate of 126 kbps in mpeg layer 3 format. video is 25 frames per second and date rate 139 kbps.
Is there a way i can get about 3 or 4 clips onto a standard dvd?
I would appreciate some help. I would prefer using 1 program cost doesn't really matter.
ConvertxtoDVD would probably get you three episodes to a disc.
A Divx certified player would allow you to burn 10 - 12 episodes to a disc as data.
Converting them manually using a half-D1 resolution and an approptiate bitrate would probably get you 4 - 5 episodes to a disc, but they would be 4:3 letterboxed, not 16:9Read my blog here.
I vote for ConvertXtoDVD. Yes, three 45 minutes episodes are the max I put on one disc. Quality from the disc is actually better than the standard broadcast since the source is HD.
I have been using TMPGEnc for a number of years, but suggest the above mentioned program due to its' ease of use, speed and the output quality (if you have a fairly high quality source). -
I use Nero to do this too. When I have a DVD that Nero thinks has too many files on it, it automatically resizes them for me. This must be a setting somewhere...
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
I know that you share the sentiment with most others on this forum. However, Nero does the job for me in this regard.
XP
600GB
2G
how many MB equal GB/ how many episodes can i fit on disc?
By janeydoll in forum Video ConversionReplies: 6Last Post: 21st Oct 2010, 10:20 -
Creating a playable DVD
By DennyL in forum Newbie / General discussionsReplies: 3Last Post: 28th Jun 2009, 23:49 -
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 12:40 -
How to copya faulty playable dvd
By decl in forum Authoring (DVD)Replies: 7Last Post: 24th Mar 2009, 12:15 -
how to fit more than 2 episodes on a DVD and be compatible with all players
By brentonboy in forum Newbie / General discussionsReplies: 18Last Post: 20th Nov 2007, 03:35
