I have an avi file that is quite out of synch in the audio/video. I ran it through virtualdub, added a delay in the audio track, and saved the resulting avi file, which then had no audio/video synch problems.
When I ran it through tmpgenc, using the avi file for both the audio and video input, the resulting mpeg was out of synch. Why did this happen and how do i fix it?
Is it possible to try to manually synch the audio video by introducing a lag in the audio or video when multiplexing an audio file with a video in tmpgenc?
Also using virtualdub, when I try to merge some avi files, the ones that are 29.97 fps merge together with no problem. If the fps is different, then obviously they wont merge. So is there a way to change the fps setting of a file to match that of the other files and if so what will that do to the viewing capabilty of the resulting file (with the changed fps)?
Results 1 to 1 of 1
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 08:27 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 22:59 -
Audio synch problems after muxing.
By avengerevenge in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2011, 20:27 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 23:22
