I need a good .avi codec so i can save videos using Virtual Dub
** They don't fit to DV standard, which is why Panasonic DV is not working with these
Which should i use? thanks
What do you want to do with the video ? If you want to do further editing and therefore retain the original quality then Huffyuv or Lagarith would be good, however they will be big - 20 - 40gb per hour depending on the content.
If you want to compress them down for viewing, but don't need to do anything else to them, then look at Xvid.Read my blog here.
Good compromised codec with alpha channel
By elmuz in forum EditingReplies: 6Last Post: 17th Sep 2010, 11:07 -
whats a good codec pack
By bmzxzx in forum Newbie / General discussionsReplies: 29Last Post: 7th Jun 2009, 19:58 -
Good codec -- Need Advice
By Bacender in forum Newbie / General discussionsReplies: 4Last Post: 14th Jan 2009, 03:36 -
Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of Sync
By hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 01:25 -
searching for a good codec for my capture
By Cazz in forum Capturing and VCRReplies: 5Last Post: 5th Jun 2008, 21:00
