I met below problem:
1. I've recorded 5 TV programmes in one DVD-RW using my DVD recorder (disc finalized). Then I cloned content of disc to PC HD using CloneDVD Version 3.9.4.
2. I opened the \VIDEO_TS\VIDEO_TS.IFO file using Windows Media Player. It clearly showed all 5 programme titles.
3. I ran TSUNAMI MPEG DVD EasyPack Suite version 3.1.5.81 and tried convert the DVD files to .mpeg. I followed the steps to import files from cloned DVD content on HD (Start new project->Set source->Add a source from a DVD-Video). But TSUNAMI only returned me a list of 4 video programmes.
Why TSUNAMI couldn't find the 5th programme but other media players can ? How could I convert this "missing" programme from DVD format to mpeg format ?
PS: Because I didn't had sufficient blank DVD disc, the original burnt disc had been emptied to store other data, the DVD files on HD was the only source now. Also, this problem was found once only. So far I hadn't found other application that could import DVD content directly i.e. other applications found like AVS Video Converter could only import individual DVD .VOB file.
Thanks! This software successfully found out the missing chapter. However, I met another problem then. vob2mpg kept on doing conversion without end. To find out the cause, I played the chapter directly using media player classic. Video play stuck after playing for a while. I didn't know whether the problem appeared when video was recorded with DVD recorder or when the video files being duplicated to DVD disc then cloned to my computer HDD. Is there any video editing software available to repair this damaged (I think it is) video file ?Originally Posted by Baldrick
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16 -
FCP - "Title 3D" Missing - but it's not!
By ehmjay in forum MacReplies: 4Last Post: 23rd Jan 2008, 08:42
