I was thinking of using FitCD in order to crop a bit of left and right side of some 2.4 aspect ratio movies, in order to make them look a bit bigger on a 4:3 tv...
At the left side on FitCD, there is a small "screen" with textboxes on all sides with the default value 0 (no crop).
Do I just have to put a numer in left and right box in order to crop? Is there anything else I have to change?
Shall I use "No cropping" or "Accurate" at the drop down selection menu below?
Approximately how many pixels should I crop? I mean how many would be "too much" and how many would be "no difference"? I have no clue!
Thanks!![]()
Keep it set to accurate to preserve the closest aspect ratio as possible and to prevent distortion.
Personally, I think any cropping is too much. You are the one with the problem, so you have to decide how much is enough to satisfy your viewing pleasure. I wouldn't crop them at all.Read my blog here.
How to crop a video?
By toqi786 in forum EditingReplies: 22Last Post: 27th Jul 2012, 22:37 -
to crop, or not to crop, that is the question...
By GrandPixel in forum Blu-ray RippingReplies: 2Last Post: 11th Nov 2010, 15:17 -
Which value I need to crop in multiAVCHD
By NZBPirates in forum Video ConversionReplies: 0Last Post: 16th Sep 2010, 15:26 -
Crop
By Benjy in forum Video ConversionReplies: 12Last Post: 23rd May 2010, 05:03 -
Handbrake: To Crop or Not To Crop
By meldavid in forum DVD RippingReplies: 1Last Post: 31st Aug 2009, 06:54
