Sonic MyDVD 4.5.2
that is the software i was provided with my dvd burner.
i downloaded some movies online which are in *.avi file format.
the dvd's i use are 4.7gb, and when i use that software to burn the dvd, it doesnt fit into one dvd ?
why is that ?
i would always have to trim the movie into half and burn the other half into a second dvd.
is there an easier way maybe i could convert the whole file into fitting a single dvd disk(4.7gb)
tq.
cheers
cheers...
u mean i could use that software ?
and it would burn directly into one dvd disk ?cheers... -
As you gain experience working video you will 'probably' not use Sonic MyDVD. I have that program, supplied with hardware purchases, and I don't use it.
ConvertxtoDVD will work for you. You simply load your avi movie into it, check out the many settings and change a few if you like. View the menu preview and customize it if you like, then hit the convert button. Now that is easy.
There are many other programs but the most of them are more manual conversions. These will require you to use a bitrate calculator and setup your mpeg2 encoder so your movie will fit whatever you want it to fit. As you gain experience you will probably prefer the more manual method. For now.... use a more automatic program like that.
Check out the guides (left side - top - of this page)
Good luck.
My DVD Authoring software stopped working and had an "APPCRASH" error
By Blueknight in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2011, 23:55 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 15:27 -
trying to pick the best dvd software player for my "old" laptops
By cubajean10 in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2009, 20:01 -
Does DVD "checking" software really work
By jbartosh in forum MediaReplies: 27Last Post: 16th Nov 2007, 20:45 -
DVD larger than 4.7GB, is it safe to use "AutoFit" and burn on 4.
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 10th Oct 2007, 15:49
