I am tying to use a Formac TV to transfer some old VHS-C tapes to DVD. I can live with the poor picture quality but it keeps dropping frames. I have a G4 1.2 with a gig of ram running OS 10.3
The Formac is older and i have to use Vidi to get the .DV files on my hard drive.
Sometimes I doubt your commitment to Sparkle Motion.
I don't have a Formac. However, one thing to try is anything that will keep the unit from getting hot. My brother had a different brand of capture device that he put in the freezer prior to using. That made it work for short captures before frames started dropping. He ultimately contributed the unit to his local landfill.
I have used this device, and although I haven't found heat an issue, because it's a generic DV capture device it pumps out data pretty fast and needs a tip-top hard drive to work at its best, ideal would be a second internal drive. I have used an external FW drive (although the order of devices along a firewire chain seems to be important) If you have to run everything off one drive, you could try repairing permissions and running the optimizing scripts with Onyx or similar to minimize unnecessary drive head activity.
Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
Honestech TVR software crashes my computer
By anbarasan in forum Capturing and VCRReplies: 0Last Post: 2nd Dec 2011, 22:56 -
Honestech TVR Troubleshoot
By alimech in forum Capturing and VCRReplies: 0Last Post: 27th Apr 2011, 22:56 -
VHS digitazing thru Sony TVR 460 s-video undetected, please help
By vatsyk in forum Capturing and VCRReplies: 13Last Post: 16th Nov 2009, 10:33 -
Hardware Requirements for TVR?
By WDude in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2007, 14:41 -
DVD-NTSC PVR/TVR capture isn't 48kHz as set to
By wguru in forum Video ConversionReplies: 0Last Post: 28th Jul 2007, 02:38
