I thought I would try to inject some humor.
here
Warning: Also, if you visit the following websites, MS Firefox 2007 will shut down your computer unexpectedly. The sites include google.com, gmail.com, apple.com, itunes.com and yahoo.com and any sites with the phrase microsoft/windows/explorer/vista/bill sucks.![]()
Results 1 to 12 of 12
Believing yourself to be secure only takes one cracker to dispel your belief.
Originally Posted by FaustusBelieving yourself to be secure only takes one cracker to dispel your belief.
lot of bad reports on FF2
Originally Posted by BJ_M
Originally Posted by BJ_MBelieving yourself to be secure only takes one cracker to dispel your belief.
I miss a couple of the extensions that haven't been upgraded yet, but otherwise FF2 seems to be stable, fast and problem free.
I have also had IE7 on another machine since the first beta, and although it seems to work well enough, it does seem very clunky in comparison to FF. In part this is because of the lack of extendability when compared to FF/FF2, and in part because underneath it is still IE.Read my blog here.
I could never get Firefox downloaded so I got it via bittorrent.
Tried it for a day and uninstalled it. Not impressed.
The feature I like most about IE7 is gthe memory release when minimized.
Load task manager and look at IE7's memory usage. Minimize it and watch the usage.
I really like IE7 so far.
LS -
Originally Posted by LSchafroth
There is a simple tweak for FF that makes it do the same thing, release memory on minimize.
Originally Posted by Poppa_Meth
if anyone is interested here's how you do it
1. Start Firefox
2. type “about:config” in the address bar and hit enter (don’t type the double-quotes)
3. type “config.trim_on_minimize” (again, not the double-quotes) into the Filter field. Odds are, you won’t have this preference but we should check first.
1. If you DO have the preference, make sure it is set to true
2. If you do NOT have the preference, add it
1. Right click anywhere in the preference list and select New -> Boolean
2. Preference name should be “config.trim_on_minimize”
3. Select true for the value
4. Close Firefox and then reopen it.
That should be all it takes. To verify you got it right, load up a few pages in a few tabs. Start up task manager or your platform’s monitoring tool of choice and see how much memory Firefox is using. Now, minimize Firefox. Check that memory usage again. -
FF2 working perfectly on this machine. Certainly better than IE7 did, and that took a reformat to get rid of...
