Hello, I've got an MPEG file which i recorded using my ATI All-In-Wonder. it's about 4 minutes and has a discreet logo at the top left. Most of the logo is actually on the black letterbox but some of it is over the actual video. I would like to remove the logo by re-applying the letterboxing again and replace it with another logo. My question is: can i do that without to re-encoding? If not then what is the best program(s) to do this with minimum re-encoding and loss of quality?
many thanks in advance
No, you can't without reencoding.
Best bet is to load it in VirtualDubMod for cropping/adding new logo, frameserve to your favourite encoder.
/Mats -
Since you'll have to re-encode it, there are external filters (DeLogo, MSU Logo Remover etc.) for VirtualDub capable of removing a logo without cropping important parts (though needs some time for experimenting to find the best settings).
The BEST way to do it is to open your mpeg-2 In VirtualDub-mpeg-2, then use DeLogo to remove the logo.
It would be best if your original file was not compressed, but hopefully, you compressed it at a high bitrate.
http://neuron2.net/delogo132/delogomanual/delogo.htm#3.3_alpha-blended_logos
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 22:10 -
How to add logo in mpeg videos ?
By ashe09 in forum EditingReplies: 7Last Post: 9th Nov 2011, 02:40 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 15:03 -
DV Capture to WMV encode. Looking for some advice.
By silmarallion in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2008, 17:02 -
Best way to re-encode 13GB DV file to 4.5GB avi/mpeg/wmv
By ColKurtz in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2007, 21:59
