Hi,
When I download avi from my MiniDV camcorder using Pinnacle 10 I get superb quality when the file is played back on my PC using any media player.
However when I compress to MPEG2 and play the file back I really see the horizontal lines from the 720* 576 resolution.
Any ideas ? I want to compress the video but I don't want to loose the quality (I guess if I knew the answer I'd be richer than I am now)
Col
Interlace. Play it on the TV, and they go away, or use a player that do deinterlacing properly (PowerDVD?)
/Mats -
Those interlace comb artifacts are in your DV AVI file too. Microsoft's DV decoder and Windows Media Player are hiding them from you by performing a BOB deinterlace while playing it. So, as mats.hogberg said, all you need to do is use a player that will deinterlace while playing back the MPEG2 file. Media Player Classic and VLC both support deinterlacing during playback of MPEG2 files. You have to manually enable it though.
Thanks - sucess comming I think....
I have Windows Media PLayer CLassic from the Klite Mega Codec Pack 1.54 beta.
I cannot see the switch in the options to turn on de-interlacing but the picture quality seems better that with regular media player.
What about my TV / DVD Player - does that have to be capable of de-interlacing ? It won't play plaing mpg files, you have to author them are a DVD...
Col -
Media Player Classic uses its own MPEG2 decoder and the decoder has the deinterlacing options. To enable deinterlacing start playing an MPEG2 file then select:
Play -> Filters -> MPEG2 Video Decoder
From that dialog select the deinterlacing option you want. I prefer BOB. -
If you have a standard-def TV, it is designed to handle interlaced video. Assuming the field order is correct, interlaced video will display just fine. If you get the field order wrong, your video will appear to jump on the TV. Restream can change various flags without re-encoding, and field order is one of them. Then you can reauthor and burn again.
I cannot speak for HDTV as I don't own one.
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W.
Great Quality AVI, Poor Resolution Creating Assembled video in Studio 14
By japentz in forum Video ConversionReplies: 8Last Post: 5th Jul 2010, 20:34 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
avi to dvd picture poor quality
By dwilson in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2009, 09:10 -
DVP5990-37.. poor avi decompression playback quality?
By Gareee in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Jan 2009, 14:34 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 01:54
