Seriously, I've been reading for two days at this great site. I've learned a lot already, but, I think I'm suffering from brain overload.
Nero (full edition) was my buddy until I realized what a crappy encoder it has. After researching, I ended up buying the TMPGENC Plus. WOW, now I am happy with the quality of my MPEG-2 files.
Basically, I'm just trying to create a DVD with menu from these MPEG 2 files I have. I was able to use one system to create a MENU layout and subsequent VOB files, but now I am having problems actually burning the DVD. eg. what program to use?
I've read about the IFOEdit, Instant CD/DVD (which I cannot find), TMPGENC DVD Author Trial version (which created my VOB's but won't burn the darn dvd...stops at 99%), Click N Burn, DVD AUTHOR GUI (which wants me to de-mux I think....but I'd be getting in over my head possibly), and lastly DVD Decryptor (whose description had said it would burn also, but I don't see that in the app.)
I'm now lost and confused. Is there an easy way to get my VOB burned to a DVD without a program trying to re-encode them like Nero does? I think my audio from TMPGENC Plus is an MPEG I Audio Layer II.
Please help!
Thanks.
BA
Read my blog here.
For dvdauthorgui ... it's really simple .
Grab vobedit , load first vob from title set ... hit demux , choose "mpeg stream" ... down below , choose "demux complete title set" check box ... and click ok .
New box will ask where file gose ... please use a new folder ... let it go and wait .
Now back in vobedit main window ... look at what it say's about audio .
... here , the hand cursor is indicating mine contains ac3 (0x80) .
Hit demux , and look at those audio options ... if you saw ac3 , then check that item ... if stream was (0x83) , then hit that arrow button and sellect from the drop down menu ... 0x80 .
The same principal applies to any other audio type found .
Now repeat ... "demux complete title set" ... check that box .
Click ok , and save the audio stream to the same folder where the video stream went ... make's it easier to locate later ... wait till completed .
Done ... close vobedit .
You can now use these two stream's within dvdauthorgui .
Should you have problem's with audio that was other than ac3 ... use besweet to convert it to ac3 format at 48khz ... then try it again . -
Thank you guys for the help.
I'm going to give this a shot tomorrow night.
When I encode with TMPGENC Plus - I think my only two audio selections were MPEG-1 Audio Layer I and Audio Layer II. I had left it at default settings.
It seems that some of the programs out there are saying I should have either PCM Audio or Dolby audio when creating a DVD.
Should I be doing something different with TMPGENC, or is it normal that I should DEMUX and then convert my audio to an acceptable format?
Thanks again.
Newb's feelin' better. lol.
I keep TMPGEnc Plus set to the defaults, demux it and feed the audio/video files right into DVDAuthorGUI. Then burn with ImgBurn. The default audio format from TMPGEnc Plus is acceptable as an input to DVDAuthorGUI.
(99% of of my DVDs are either source from MiniDV cam footage, or IPTV shows (like DL.TV) that I want to watch from the comfort of my reclining sofa
Cheers,
Jim
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Help reading .yuv files
By lotsoflayne in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2009, 21:09 -
Reading VOB files
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 10th Nov 2008, 16:55 -
confused with divx files that work
By ceve4life in forum Authoring (DVD)Replies: 3Last Post: 30th Jul 2008, 17:42 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
