Hi everyone! Thanks in advance for your help..![]()
Here's my problem..
I'm capturing some video from a digital cable receiver (Scientific Atlanta Explorer 3200). My capture card is a Hauppauge PVR-250.
The receiver is in my linving room and my PC is in my bedroom.
There are always some horizontal lines that are appearing at the bottom and going all the way up of my captured video. I uploaded a frame from the video so you can see it.
If I plug the receiver in my bedroom and use the same cables to capture, the problem's solved..
I really don't know what might causes the problem.. I have a home theater in my living room... Can there be some conflict with the amplifier or something..(electric, magnetism..?)?
Thanks a lot 4 your help!
main.dvd
You have a ground loop problem. Try plugging the devices into the same outlet (hard to do if they're in different rooms).
Is there any other solution, like some kind of device (ground loop isolator, like for audio) that can solve the ground loop problem ???
Thanks for your answer! -
I've heard of video ground loop isolators but I have no idea how well they work. I seem to recall they cost a lot more than audio ground loop isolators.
Does somebody know more about those video ground loop isolator and where I can found them?
Thanks! -
Most cable companies only charge like $5 or $6 extra a month for a 2nd cable box. That way you can have one near the TV and one near the computer and hopefully with that setup the one near the computer will, like now, not have any "issues".
Very Poor Video/sound quality
By mikey56hernandez in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2011, 20:27 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Poor Video Quality
By itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 16:32 -
Poor video quality full screen
By gman0417 in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th May 2008, 08:00 -
errors on side of video, horizontal bars from top to bottom
By norcent33 in forum Software PlayingReplies: 2Last Post: 26th Jun 2007, 10:48
