I'm frameserving from Vegas using Debugmode Frameserver.
I'm serving to Virtualdub 1.6.10.
Video compression is DIVX 6.4 (most current, anyways) registered.
Has anyone or can anyone confirm that the last 1 or 2 versions of DIVX has made multipass encoding using this method impossible?
I've never received an error before, but now I'm only able to encode 1 pass. My only guess is something has changed with DIVX to make this approach/method not work anymore.
On the first path, I'm not using any WAV audio. I normally only encode that into the stream at the final "nth" pass.
Hi! I have the same thing! Using either VirtualDub or TMPGenc 3 XPress, when frameserving from Adobe Premiere Pro 2 and choosing multipass returns output error. 1-pass works fine. I don't remember which version of DivX I previously used for encoding, but it worked fine with the same configuration while selecting multipass. Did you find a solution for it?!
Nope no solution as of yet.
I can perform the same task with XVID final, no problems, but not DIVX. -
Hi all
I would like to confirm the same issue with TMPGEnc 3 (fully patched to latest version) Xpress and Divx 6.4
I have found somwhat of a solution though - its all about where it is storing the log file for the first pass. If i change the temp directory for Divx before encoding (its in advanced) to the same location that TMPGEng is putting its temp files (its in preferences within the program) it *seems* to work.
I say *seems* because i have a feeling that although it is working and outputting a video (more than it was before), it is only doing one pass, as the quality of the video i just did via this method was _bad_. I dont have time to check at the moment though and probably wont have time to mess till next week. Then again it could just be another setting i messed up somwhere.
Previous DivX versions in the 6.x series did not have this issue.
Somone wana fire a email off to them ?
Regards
Divx multipass encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2009, 13:31 -
Multipass Encoding
By lcphr3ak in forum Newbie / General discussionsReplies: 3Last Post: 11th Jan 2009, 23:41 -
What exactly is the problem Virtualdub has with Divx multipass?
By Onceler2 in forum Video ConversionReplies: 14Last Post: 20th Aug 2008, 19:00 -
How does DivX multipass work?
By moviebuff2 in forum Newbie / General discussionsReplies: 27Last Post: 7th Sep 2007, 09:03 -
DVDx 2.9 : improved AVI (DivX/Xvid) multipass support
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 17th May 2007, 10:34
