Hi All
I have been playing AVI files for a long time using VLC and there have been no problems. However, I have latley been finding that most movies are hitting a certain point and the picture is stopping (the sound carrys on). It seems like there is a break in the file and it crashes.
Anyone know why I shoudl have this as such a big problem when it didn't use to be? Also how can I patch up these files? I have downloaded GOM because I hear it helps with broken AVI's but it seems GOM doesn't play a lot of the file types that are broken.
Any ideas whats happening and how to fix it?
Cheers
If it has only recently started happening, my first thought would be either you really need to defragment your HDD, or your HDD is on the way out.
I would start by running a scandisk in thorough mode. Once this completes, defragment the entire drive. If it is really bad you may have to defragment it more than once.
After that, try watching the videos again. If they have been corrupted then all you can do is throw them out and start again, or spend time trying to edit out the corruption.Read my blog here.
Load the AVIs in VirtualDub or DivFix, and see if either has problems with the index of the AVI files. I think GSpot (version 2.52 or better) should also be able to tell if an AVI's index has errors.
If cameras add ten pounds, why would people want to eat them? -
Are these avi files created from combining multiple avi files?
Google is your Friend
Video Keeps Stopping On My Site
By Frustrated1 in forum MacReplies: 16Last Post: 5th Apr 2010, 00:59 -
Play divx files without stopping
By occasional in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Feb 2009, 07:20 -
Sony RDR-HX750 Stopping for copyright
By rtimboz in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Jun 2008, 13:42 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 17:45 -
Capturing and stopping via command line
By diamond187 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2007, 16:03
