    Oct 2006
    Bosnia and Herzegovina
    I purchased MBP to use it, among other things, for VJing. A lot of great VJ software is available for both OS X and Windows platform and i use it both.
    I purchased DVI to S-video adapter and connected MBP with projector and it worked perfectly well.. Then I switched to Windows and tried to get the same thing but I couldn't get anything on projector. I guessed that it could be something wrong with adapter so I tried to connect regular monitor directly to MBP DVI out and it didn't work as well... Got back to OS X and it worked perfectly.
    Under windows, when i plug DVI adapter to DVI out, it recognize "something" and it allows me to add secondary display in graphic card settings but doesn't output anything. I tried to replace original ATI drivers with Omega alternative but that doesn't make any difference...
    Anybody had similar problems? Is this driver/compatibility problem or it's just my MBP?
    Any solutions?
    Thanx!
    Oct 2003
    Canada
    Under Bootcamp? If so it is still a beta and all features might not work. Try it through Parallels virtualization (free to try).
    http://www.parallels.com/en/products/desktop/
    Aug 2006
    I have a first gen MBP 1.83ghz with boot camp installed. At first i had no luck with using an external monitor while in bootcamp. after doing some searching on the net, i got it to work. Basically you have to fudge around with the ati catalyist tools a bit and it will work. This was months ago so i don't remember the specifics but, i know i got it to work. This was also with the original version of bootcamp, so i would think with newer releases it should be easier to accomplish
    Check out My Latest Project, "Fishin' with RV" on Youtube.com
    Might also try reducing the refresh rate of the adapter under Windows. Just a guess.
