I have been using WinTV for awhile now but I am getting tired of it malfunctioning on me and now it saves the files as avi files which makes them huge.
Can anyone recommend a high quality capturing device? Thanks!
Canopus ADVC-110 but it doesn't have a TV tuner only composite and S-Video inputs.
Hauppauge WinTV PVR units are hardware MPEG capture cards. Work much better than the old WinTV GO cards (sounds like that is what you have).
Good models are the WinTV PRV 250 (PCI), WinTV PVR 350 (PCI) or the WinTV PVR USB2 (external USB 2.0).
Can someone recommend a good USB style tuner device for me
By True Colors in forum Capturing and VCRReplies: 0Last Post: 31st Jan 2010, 15:12 -
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 03:35 -
Recommend device please
By stompinne in forum Capturing and VCRReplies: 2Last Post: 28th Dec 2008, 12:46 -
Having problem(s) with my Capturing device
By Adoll in forum Capturing and VCRReplies: 0Last Post: 5th Apr 2008, 12:58 -
What device should I use for capturing?
By Heyjoojoo in forum Capturing and VCRReplies: 4Last Post: 24th Sep 2007, 17:56
