I tried to record an streaming .asf file (I used cocsoft streamdown.). But when I try do use or edit this file; it says it's copyright protected. Is there a way (some kind of software) to get around that and save this stream as an avi for example and edit it anyway?
thnx in forward
If you have a license, yes...try fairusewm
If you don't have a license, then you are out of luck.Google is your Friend -
GOOGLE it! you can find good DRM cracker worth taking the risk if you hardly want it
after licence nothing
By ve2srz in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th May 2009, 09:51 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
