Hello. I encoded a 23.976fps movie with CCE using the following little script:
On CCE, i didnt click on any framerates. Left it as it was, 23.976!# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =-
AVISource("C:\movie.avi")
LanczosResize(720,576,0,0,484,264)
#Trim(0,182662).FadeOut(150)
ConvertToYUY2() # For VirtualDub or CCE
The produced .MPV is at 29.97fps. HOW COME?
Here are the GSpot results:
AVI=> Pics/s: 23.976, Frames/s: 23.976
MPV=> Pics/s: 23.976, Frames/s: 29.970
Why did it change the framerate on its own??![]()
Maybe you have the 2:3 Pulldown box checked?
What are you trying to do, convert a 23.976fps AVI to PAL DVD using the DGPulldown method? If so, then run that same MPV through DGPulldown with the Custom Box ticked and 23.976->25 filled in. -
It hasn't. The number of frames (or pictures, in g-spot speak) is still 23.976. CCE also applies Pulldown, which gives you playback at 29.97 fps on NTSC devices. Obviously you are converting NTSC to PAL, you now need to open this file in DGPulldown, and change the pulldown to 23.976 -> 25 fps.
Read my blog here.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
