Having problems with converting a vob file from dvd decrypter into a mpg file with vob2mpg.
Made the vob in file mode, no splitting, one main vob.
I installed vob2mpg with no problem in RC1 vista. I selected the vob folder as input and another folder as output and clicked start. The progress bar finished in like 1 second.
The result was a mpeg file with 0kb in the output folder.
Any suggestions
Mike
Did you try clicking start again without closing the program? I have had the same thing happen and usually just trying again works, no guarantees though.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Ok. It's working now. For some reason ripping with dvd decrypter in file mode did not work.
But ripping in info mode did.
Mike -
As I said, i have had it fail on occasion, but it usually works. I did have one disk that would not convert no matter what, it ripped fine but no editor would touch it either so there had to be an error in the video somewhere.
Are the discs scratched? Are they newer protected discs that might require something other than just DVDDecrypter to properly rip?Dwight
- Herm Albright
vob2mpg
By peebee44 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Dec 2011, 16:02 -
Unable to install VOB2MPG or VOB2MPG PRO
By tooc in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Mar 2010, 01:53 -
Error when launching VOB2MPG 3 PRO in Vista Ultimate 64bit
By ghostwulf in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 20th Mar 2009, 06:28 -
Vob2Mpg 3 doesn't like Vista Glazz
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 17th Mar 2009, 22:17 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01
