i fixed my .avi overscan through FixCd then i encoded it in tmpgenc express 3.0 and made my dvd through nero 7 some reason after i make the dvd and play it in a stand alone dvd player some parts of the dvd freeze for a second (about 4 times for every 30 min episode). All of my other files that i just encode through nero and play on my dvd player work fine. does anyone have an idea what the problem might be.
so i guess i use nero to write files to hard disk after i make my dvd then use dvd shrink to make an iso file then use image burn to burn image am i right.
No. You don't put Nero in the equation at all. Nero should not be allowed to touch DVD video, ever.
if you don't want to spend money, I suggest you encode with tmpgenc express, author with GUIForDVDAuthor, and burn with imgburn2. No Nero, No Shrink.
If you do have a little money to spend, consider TDA instead of GUIForDVDAuthor.
Imgburn2 doesn't require an ISO, it can burn from a folder.
Why don't you want Nero involved ? Because Nerovision has the unfortunate habit of needlessly encoding perfectly good, DVD compliant video for no good reason, lowering quality and wasting time.Read my blog here.
1080i 29.97 frames/sec to DVD compliant SD using Avisynth and HC encoder
By johnnyquid in forum Video ConversionReplies: 2Last Post: 25th Jul 2011, 16:24 -
Recording 1080i 60 fields/sec vs 1080p 30 frames/sec
By johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 20:40 -
more dvd freeze problems
By dblake2 in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2008, 12:27 -
dvd architect 4.0 chapters freeze.
By rb_jr in forum Authoring (DVD)Replies: 4Last Post: 4th Jan 2008, 10:38
