Hello, I downloaded a video in PAL format of a Bob Marley video fron '79 and '80. The video consisted of four titles.
I split the video with DVDshrink into the first two and second two titles to fit on two DVD5's.
I then used isoedit to switch to NTSC, and when I burned there was a green plasma border on the top third of the screen and a small green border on the bottom.
Any idea why?? I know it's not on the video...
I guess border isn't really the right term since it actually covers a significant portion of the video itself, not just as if I switched from widescreen to full.
I also tried switching the aspect ratio from 4:3 to 16:9 with the same results. Thanks so much for any advice!
This is what happens when you don't actually convert the video to NTSC, just try to fake it. True conversion from PAl to NTSC requires resizing and re-encoding the video. These simple patch methods don't really do anything to video, they just to to fool the player. Some players can be fooled, many cannot. Obviously yours is one that gets confused.
Read my blog here.
A few more methods of PAL>NTSC conversion: https://www.videohelp.com/convert#4;41
BTW, this can be one of the more complex conversions. You might have to do it with one of the 'long ways' to get good quality.
I use ConvertXToDVD if I want an easy way and it handles most formats fairly well. If not, then look to the link I posted and try some other methods.
The green sounds like a problem with the codec that plays the video. This is more common when playing the video on a computer. Are you seeing the green on a standalone DVD player output?
And welcome to our forums.
Thanks guys, I appreciate the info...
Yeah, it only plays like that on my dvd player, not on the computer.
I'll try to do the true convertion...thanks for the links!
Can I remove black bars (top and bottom) when backing up my dvd's?
By jammiev in forum DVD RippingReplies: 10Last Post: 17th Jan 2012, 14:19 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
Top & Bottom border
By burgin in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2011, 19:31 -
Top and Bottom subtitles on dvd
By loster in forum SubtitleReplies: 3Last Post: 1st Aug 2010, 00:34 -
grey areas on top and bottom of ws dvd or vob file not on avi
By bobb52 in forum Video ConversionReplies: 3Last Post: 5th Feb 2009, 01:04
