can smb name a few capture programs that support capturing from dv directly to mpeg 1/2 with timecode?
tks
I'm not aware of a program that will do the capture, timecode and MPEG directly. However, you could use an MPEG encoder (e.g., CCE) and our Enosoft DV Processor - this will let you capture DV and add the timecode as it is being captured. Once that is done, you can use CCE (or some other MPEG encoder).
John Miller
Looking for SVHS PAL capture device with timecode support
By nf42day in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2011, 14:43 -
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 09:24 -
Burned in timecode - HOW?
By synaptic in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2009, 23:41 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00
