Hi,
I am trying to convert my movie to dvd using ConvertXtoDVD....however my movie is split into two 700mb avi files....e.g CD1 and CD2
I tried adding both files but they seem to show up as two seperate files on the dvd menu.
I would obviously like them to be played together as one whole movie.....should I join the files first using something like virtualdub and then add them to ConvertXtoDVD....thanks
In ConvertXtoDVD, after adding your 2 CD's go to Settings/Authoring and the click on Sequential Playback and then convert. Both parts will be joined.
Worth a try, but unless they have changed things recently, all this will do is make them play back continuously. They will still be two separate titles and appear as two references on the menu.
Either join them before hand (risky, often produces audio problems), or convert with ConvertXtoDVD, and import the results into TDA. Put both halves on the same track, remove the chapter stop automatically placed at the start of part 2, and the playback should be seamless.Read my blog here.
Hi there,
But will senquentially play on your DVD player is you have enabled [X] Sequential Playback.
A true merge, 2 .avi to become 1 DVD Title will only be supported in the future I was told by VSO Software Officials.
Movie Maker files not encoding in ConvertxtoDVD properly
By KJShearer in forum Authoring (DVD)Replies: 2Last Post: 27th Aug 2009, 18:23 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 07:49 -
ConvertXtoDVD wont burn movie
By hewhoeatsall in forum Authoring (DVD)Replies: 1Last Post: 14th Dec 2008, 19:58 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 10:54 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00
