Had a (rare) reason to convert a wmv to DVD. The wmv was 480x360, 530 kbps.
As I know (since previous encounters) wmv is a stubborn source to do anything useful with, I tried Super, which I know can take just about anything thrown at it and encode it to almost anything. Using high quality, and 6000 kbps, the result was this (a random point in the video):
I then did it the hard way: Load wmv in VirtualDubMPG2, resize and saved as DV AVI (since my MainConcept refuses to read from VDub frameserver).
Encoded DV to mpg at the same bitrate as Super with MainConcept:
I think I don't have to tell you which version I kept, and which I dragged to the trash can.
/Mats
No idea, really. May be so simple as the resize algorithm used for all I know. In VDub, I used Lanczos3.
/Mats -
Yes, it's resized from 480x360 to 720x576 in both cases.
/Mats -
I believe a WMV file can contain multiple video streams with different bitrates. Could that be the case with your WMV file? Maybe Super got a low bitrate stream and VirtualDubMPEG2 got a high bitrate stream.
That could be. How to check? WMM refuses to play the wmv, or I'd used WMM to save out to DV as I've done before.
/Mats
Super 8 film, eliminating "pull down" effect
By szilagyic in forum RestorationReplies: 94Last Post: 4th Nov 2014, 18:39 -
Is Super known to install any "extras" other than OpenCandy?
By brassplyer in forum Newbie / General discussionsReplies: 61Last Post: 17th Nov 2013, 09:45 -
Is "overclockable" a real tech term?
By yoda313 in forum Off topicReplies: 6Last Post: 22nd Jul 2011, 17:43 -
the real reason toyotas are so "reliable"
By deadrats in forum Off topicReplies: 6Last Post: 13th Feb 2010, 09:47 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 13:01
