Hello everyone,
I,m trying to back up a PS2 game i was just wondering which is the best program to use to do this and how i go about it because i have been using Alcohol 120% but am having problems so if someone can help me out that would be great, not to sure if i can ask this about PS2 games but let me know either way
Results 1 to 18 of 18
Any program that can copy a dvd can copy a PS2 game.
What game is it?
Maybe you're trying to copy a DL game? -
DVDDecrypter ISO Read, ISO write. Not harder than that. But you need a mod chip, swap trick or exploit to play the backup.
But this is no game site. Moving you to off topic.
/Mats -
yeah i have a wap magic cd and magic keys i,m trying to back up raw vrs smackdown how do i use dvddecrypter iso read , iso write i did the iso read to hardrive and then when i went to write i couldnt write it ??
Originally Posted by drew23977
/Mats -
Ok this is what ive done to my PS2 and what software im using and progrmans ive burnt with.
I got Swap Magic 3 plus yesterday tried it and didnt work i was told you need some magic keys for the sensors so been me and couldnt wait i open up the PS2 and fond sensors 3 of them taped the one above the power switch down and the cd brake and the sensor for the lid i'm guessing first i tried to back up WWE RAW VRS SMACKDOWN all that comes up is the loading symbol and then checks memory cards then loading and stays like that i also tried pressi one aswell after that i thought well maybe its just the game so i tried a different game FIFA 06 EA SPORTS i use DVD DECRYPTER and ALCOHOL 120% and the same all i get is the FIFA 06 Loading so it must be something Ive done wrong all 3 Sensors are down or but where they should (ie Disc Brake) is there another sensor Im missing please please help me out -
Unless anyone here also uses Swap Magic 3, I'm afraid this is the wrong place for this kind of issues. There must be some Swap Magic fora around the web?
/Mats -
Can i ask one last question FIFA 06 is Running but it is real slow are PS2 copies always slow or are they just the same speed as a orginal
Slow loading is common - use better blank media, burn at slowest possible speed. You risk frying the laser with weak burns.
/Mats -
First off what model PS2 do you have ?
One of the newer slim line with the top opening door or the older style with the opening tray ?
The slim line has two micro switches (sensors) (maybe 3, been awhile since i had mine open) that tell if the lid has been opened or is open, you must bypass these keeping them closed at all times so even when the lid is open it think's it is closed.
I have backed up both smackdown Vs. raw games, the original & the 2006 & both run fine, all of my games i have backed up do, and i use both swap magic & swap magic 3 coder boot disc's with no problems, on my slimline & my son's older original version PS2.
Games loading "slow" and "Running" slow are two diff. things, they all load slow, even my originals, i have never noticed any time diff. between the two.
No they should not run slow!! a backup sould play exactly like the original.
I always use DVDDecrypter for my game backup's, ISO read, ISO write.
I alway's use good media (Verbatim) +R's bookedtyped to dvd-rom & alway's burn back to dvdr no faster than 2X.
mats, did you forget your coffee today :P -
I personally use -R, but as Noatuck burn at 2x
Sometimes by backups have a hard time reading intro video and stuff, but generally once they play, they play fine. I use el cheapo media most of the time.
/Mats
PS! And I've had my coffee...DS
I have the slim line PS2 with the flip lid and have sorted out he sensor above the on light and the disc brake and also the sensor on the flip lid I was burning at max speed but i wil give it a go at x2 when you guys backup movies do you guys do it at the same speed or max speed getting back on the subject i will report back after i have tried it at x2 speed and see what happens any other advise is much appricated when i said it was slow i ment the loading processl ike on fifa 2006 the intro video keeps freezing thats what i meant when i said slow also it is real slow compared to the orignals
The BEST non-mod solution is: Hard drive w/HD Advance. Forget modchips and that flip-lid garbage....
Zero modifications are required, its plug&play. Lets you play original, import, and back-up games. Plus you can load all your games onto HDD, and loadtimes from an HDD are MUCH faster.
Most internal Pc Hard drives brands will work, with the exception of a few like western digitals.
And if you have a newer model PSTWO without the hard drive bay, you can use an external USB HDD just as easily. -
I bought the HD Advance with usb Xtreme. Free copy software is available from the site. You copy the game to a usb drive, plug it in to the PS2(slim model) boot from the HD Advance DVD to their GUI, pick which game to play. It can't get any easier than that. My grandkids are hell on the disc and this was a wise buy for me.
Originally Posted by JimmyJoeBob
If you know someone that has a ps2 that is already modified you can create a memory card save with the HD advanced already on it and use a psone game to boot the hd advanced program so you dont have to buy the disk also
ITs a great peice of software
(The hdavanced on a memory card will work on a non modifed console) -
Originally Posted by ps2daddy
Edit: Then again from how your post sounded, i would have to boot up a PSOne game first before being able to load HDAdvance from the memory card. Meh might as well keep using the HDA disc, since i already have it. -
here is the info
http://www.exploitstation.com/index.php?page=articles
Backing up The Sims Triple Deluxe PC game
By angelsblaze in forum ComputerReplies: 4Last Post: 4th Apr 2012, 05:49 -
PSP Game to PC?
By mysts in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 20:46 -
Ripping Audio from PS2 Game Bully?
By coondog1234 in forum AudioReplies: 2Last Post: 10th Mar 2010, 09:47 -
how to backup pc game
By buck696969 in forum ComputerReplies: 14Last Post: 12th Jan 2010, 13:21 -
Backing up my PS2 games....
By SE14man in forum ComputerReplies: 23Last Post: 16th Jan 2008, 11:12
