I am successful make a VCD from DVD using this forums procedures as: Smart Ripper first, DVD2AVI second, then TMPGEnc last before using Nero.
The result is satisfy for me. But it only record the default languege spoke and also no language display (like closed-caption display on TV)on the TV.
Is there any easy way I can do to make the closed-caption display AND select any language I want that is avilable from the DVD)?
I just get error until I do Run -> Start Conversion.
The error said:
'FlaskMPEG.exe has generated errors and will be closed by windows. You will need to start the program. An error is being created'
I am using window 2000. Help! -
I got it from http://www.vcdhelp.com/dvdtovcdflask.htm
I think it is 0.6 preview 1.1 -
I think you sould try FlaskMpeg 0.60 subtitlefix.
You can get it here:
http://www.doom9.org/software.htm
If till have a prob, try in Win98SE.
I use FlaskMpeg 0.60 subtitlefix, LSX & CCE plug-in, WinXP with no problem.
Johncc35. -
Anyone used FlaskMpeg 0.60 subtitlefix on Window 2000 and made it through the process without any problem?
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
How do I name multiple srt files so that the language shows to select?
By JoeBolden in forum SubtitleReplies: 0Last Post: 29th Apr 2009, 13:02 -
All-In-One Video Selection / DVD Record Source Select
By Frank-0-Video in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2009, 12:24 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Foreign language title display in car MP3 CD Player !!!
By homantam in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2007, 07:37
