After a I burn my converted AVI to DVD, the DVD movie has a jerky image. Sound is fine. The DVD image is also jerky when I play it using my DVD player on my Mac. However, when I play the file using the VLC player, the image is fine.
Thanks for any help,
Edwin
Much more info is required. Software used, framerate etc...
He's a liar and a murderer, and I say that with all due respect. -
I burned the DVD to a DVD-R using my Mac's burner. I'm now trying it using Disk Utility to see if this makes a difference.
Here is what I used to create the DVD: FFmpegX 0.0.9x mpeg2enc mpeg2, 720x480, 4000 kbps, 23.976 fps, no crop
I'm a neophyte to this and this is my first attempt at creating a DVD from AVI or other format.
Thanks,
Edwin -
Since this appears to be a Mac related question, you would likely get better answers in our Mac Forum. Moving you.
And welcome to our forums.
My guess would be that the NTSC Film framerate (23.976 fps) is the cause of a jerky image.Originally Posted by edwindark
To fix that, you'll need a so-called "3:2 pulldown". Next time set the Set 3:2 checkbox.
(Alternatively, you can also add a 3:2 pulldown to an already encoded mpeg video file, by using the Pull tool. Input here is an elementary stream (video-only file). You may have to rename your .mpv file to .m2v, because this tool is picky about the suffix. Then multiplex the video-with-pulldown with your audio in the Mux tool.)
This leaves your video unchanged, except that playback equipment now knows how to feed it to NTSC output devices (e.g. a tv), dealing with the desired 25% more frames (23.976 to 29.97 fps) and interlacing. Result is a smoother playback.
_________________
For more on ffmpegX, see the ffmpegX forum on Videohelp.com.
Image jerky after converting a DVD to MKV
By siocnarf in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 14:14 -
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 07:13 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 13:45 -
Vegas 8 - replace an image with image from previous frames
By sdsumike619 in forum EditingReplies: 2Last Post: 5th May 2008, 14:26 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
